Sorry if I'm posting in the wrong place!
The "arrange all" setting used to work automatically (as a default?) but now when I open a new image I have to do this manually. Very annoying!
How can I fix this?
Thanks!
Kris
Wondow/Arrange all
- Système d'exploitation : windows vista
Re: Wondow/Arrange all
Hi Kris,
Near the Window menu is a View menu. They have both related functions.
In the View menu if you uncheck "Maximize window when opening" does it solve your problem ?
Yes, that was the info I needed.
Thanks a million. This will save me so much time!
Kris
Kris
Welcome Kris, don't hesitate to post a new question.
