Capture - client area in Word
sorry, I don't speek French.
The Photofiltre is absolutely perfect, thanks.
I have any suggestion to plugin Capture writen by Benjamin FOURNIER:
In html files works the option "Use vertical scroll", but this doesn't work in
doc files. This may be difficult, I know, but I like to see it very much...
Thanks, Zdenek
Thanks, Zdenek
- Membre d'honneur
I am not sure, if this can help to solve your problem, but easy way of geting pictures embedded in word / excel is to save the document as .html file. When it is saved, it generates the .html file and a folder containig all pictures
Sometimes - in older versions of word - this option was not in "typical installation", so it is necessary to start setup of the MS Office and check the option
FrançoisL > Yes, I thought so too , but I tried to ask.
SuE > OK, but I need to save a doc (simple) site as an image because of correct displaying of unusual fonts and non ascii characters on other computers (saving doc with embedding fonts is often uncorrect). I tried to use PdfCreator to create bmp file, this may be not coorect too.
this may help for a while (it is 30 day trial )
The program simulates a printer and creates a picture:
http://www.zan1011.com/download.htm
this one should be free but there is some key necessary for .doc (may be only to avoid ads, I do not know) :
http://www.omniformat.com/faq.html
But these programmes give not an authentic copy what is on the screen - reproduces vector fonts etc.
What I seek out is http://www.pixelmetrics.com/CapWizPro/ (this works like the Fournier plugin, but in Word, too).
Hi Zdenek,
I'm possibly late to answer, but i use daily a virtual printer that is PdfCreator.
This tool is quick, stable and gives images of rather good quality for a very light pound in file.
Here is a link for a french site to download it, but i think the gnu community has other site in any langages.
http://sourceforge.net/projects/pdfcreator/
Edit : 2009/06/11
This is a 32 bits software for i386 architecture.
Edit : 2009/06/11
Re: Capture - client area in Word
A lot of pdf creators do not support 64-bit OS. Today I have discovered new PDF Printer. It works ok on my 64-bit XP.
This is what I needed...
Thanks!
Thanks!
