Guys, I have starting using layers. I note I can save a layered imageas a PFI, save it, then open it with the layers till showing - how it should be right? If I merge all the layers and then save it, I open it, see the one merged layer but I want to take the image back to the layered version? Once merged is it too late to re open?
Ian
Saving PFI's
- Version de PhotoFiltre : Studio x
- Système d'exploitation : Vista
- Processeur : Quad Core
- Mémoire RAM : 2mb
Re: Saving PFI's
after saving a merged image you can not undo it
