Plugins Pack to download PF and PFS plugins
Here is the plugins pack : PPP.
PhotoFiltre Plugins Pack makes it easier to download and install plugins for PhotoFiltre and PhotoFiltre Studio.
It doesn't need any advanced knowledges to be used.
Downloaded and installed plugins will always be up to date because they are directly downloaded from the PhotoFiltre site.
Plugins are completly installed in the right folders (with the help file, if available).
Author : Heis Spiter
All the steps help texts are wroten in 3 languages : English, French, German
The download file is very light : 132Ko.
Heis Spiter's server (Version 1.4.0 - Updated)
Link 1 (by HTTP)
Link 2 (by FTP)
Site : Papy 35 (Version 1.4.0 - Updated)
Link
Page perso Free Tom (Version 1.4.0 - Updated)
Link
Page perso Free FrançoisL (Version 1.2 - Out dated)
Link
PPP is Windows Vista compatible (since release 1.3.2)
You can control your download with these following checksums :
MD5 : 863b0b1dcf085e7c0ce124e89b956b99
SHA1 : 274a5ca4e21a7142cfb26e26896692bac9a3b7b5
SHA256 : b9b5b657cdba99ced3afea8305938fdc9ddf223b37659543fbea0fdfa89348a2
Support of this software should be done following this topic.
Updated : 2007/08/24
Link 1 (by HTTP)
Link 2 (by FTP)
Link
Link
Link
- Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
- Système d'exploitation : Win 7 Home Premium SP1
- Processeur : AMD II X2 Athlon 265 3.3 GHz
- Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Re: Plugins Pack to download PF and PFS plugins
Ok. Thanks.
- Version de PhotoFiltre : Photofiltre 6.3.2
- Système d'exploitation : Windows 7 Home Premium
- Processeur : Intel Core 2 Duo 3.0Ghz
- Mémoire RAM : 4Gb
Thank you all for your plug in support and a fantastic program. These files have worked perfect for me on Win 95/98, Windows XP, and Windows Vista. However I thought that I would stop into the thread here and leave a quick note about a problem that I have encountered.
The Plugins Pack version 1.4.0 does not work right in Windows 7 (Home Premium, 64 bit). It loads fine, but when it gets to the screen that says it is "Connected to the server. Downloading the file." it stops responding. My only option is to close the program at this point. Is there a possible connection problem to your server where the files are being downloaded from, or could it be a Windows 7 issue? I do not have any other firewall installed outside of the one that comes within windows. I have tried to run this program as Administrator as well.
Thank you for your time,
the problem is not windows 7,the plugin pack must be updated (some site changes)
- Mémoire RAM : 4Gb
Thanks for clarifying that. I look forward to the update!
Take care,
Take care,
- Version de PhotoFiltre : 10.3.1
- Système d'exploitation : Vista
- Processeur : Intel Core Duo T6500@2,1 GHz
- Mémoire RAM : 4GB
Is there any chance to get an updated version next time?
- Version de PhotoFiltre : 64
- Système d'exploitation : win xp
I tried to download your plugins pack (pf-plug.exe and pf-plug_v1400.exe)
Using Firefox 3.6.8 and opera 10.61 and Internetexplorer8 ... all three browsers producing.
allways downloading problems: Either after "succesful connected to server" nothing happens.....
or after dowloading at the end error message: "DIE LISTE IST NICHT MEHR IM ADÄQUATEN FORMAT"
What is wrong here ??
Antonio told me to download newest plugin-set :
http://www.photofiltre-studio.com/plugins/PPP_II_EN.exe.. (I downloaded)
I was thinking according to ..... _EN this would be the english version, but it is a plugin-set in french language.
Is there an english version available also ??
please give new download adress
thanks
thanks
sorry file ppp_II.exe and ppp_II_EN.exe have the same content
using french language ??
I think there are some confusion, plugins use the language of photofiltre, if your PhotoFiltre are french, plugins will be french. Some plugins are french only or english only, see the doc of each plugin
Hallo, everybody! I have a problem with installing this plugin-pack on PhotoFiltre 6.5.2 Portable. I have there English and Russian, tried to install with English on default.
By installing it shows the window with the text: "The file format is not correct". How can I install this plugins on portable PhotoFiltre?
Hi,
you are using an obsolet version. You can find the new PPP_2 version in the posts above,
or on the good page of the official web site : (see quite down the page)
http://www.photofiltre-studio.com/plugi ... ins-en.htm
