Lambourne, your PhotoshopFilter plugin now works with Ximagic v4.2.3 (26 mar, 2012).
See changelog: http://www.ximagic.com/d_changelog.html
- Version de PhotoFiltre : 6
Re: PhotoshopFilter plugin
Hi Lambourne,
Very Good job, It works fine !!!!
that's great ,indispensable, perfect.
thank you very very much
- Version de PhotoFiltre : 7.0
- Système d'exploitation : Windows
- Processeur : AMD
- Mémoire RAM : 4Gb
Hi, fella! Here is a new version of plugin. Now it is renamed to 8bfFilters due (Photoshop) copyright restrictions. Also there are a multilanguage support and also plugin options will be stored in registry, not in config file - so there are no need in write permissions for PhotoFiltre folder under Vista/7.
You can download new version in same site as before.
Thanks all for your support!
Plugin added to the plugin page
Very good, Thanks for the input, plugin installed and running
