Associate file types to PF
lianergoist
Message par lianergoist »
Hi
It would be cool if I could associate file types to PhotoFiltre from within the program itself. As it is now, I use "Open with..." and click "Use this program next time..."
But it doesn't really work. If I choose to open more than one image, then more than one instance of PF is opened (one for each file).
I do know how to edit associations, but I don't know how the command line should look. Do I need to use DDE? How should the commandline look?
Thanks....
Thomas
delphiuser
Version de PhotoFiltre : 6.0.2
Processeur : PIII 1GHZ
Mémoire RAM : 128 Mo
Message par delphiuser »
Hi :D ,
To associate file types to PhotoFiltre, you can use the plug-in "Association" 8)
You can find this plug-in directly in the web-site of PhotoFiltre :lol: ...
delphiuser.
