Hi!
Is it possible to cut out an object on a picture so that the background is deleted? I think it works by using the lasso tool. Unfortunatly I can only find autocrop but this doesn't work because it can't find the edges...Would be nice if you could help me...
thank you
recorder
cut out image leave away background
Hi recorder,
you should look the tutorials of the official site of PhotoFiltre :
http://photofiltre.free.fr/tutorials_en.htm
and especialy this one :
http://photofiltre.free.fr/tutoriels/op ... ipping.htm
You can see also, after a quick selection on a subject, this function :
Menu Edit / Optimized clipping.
The best way to proceed, for me : using the polygon selection tool and paste as new image to detail the edges with a little white brush, or Blur tool.
Have you tried to inverse selection and cut ?
