Voila, Je pense avoir résolut ces problemes avec "Application.ProcessMessages" bien placé et une poignée de tests.
Si vous pouvez Re-Re essayer, la nouvelle version est "OnLine" (yea)
Encore merci
A+
Code : Tout sélectionner
Loaded "LENTILLE.PFL" at address 0x014A0000. Successfully hooked module.
DllMain(0x014A0000, DLL_PROCESS_ATTACH, 0x00000000) in "LENTILLE.PFL" called.
DllMain(0x014A0000, DLL_PROCESS_ATTACH, 0x00000000) in "LENTILLE.PFL" returned 1 (0x1).
DllMain(0x014A0000, DLL_PROCESS_DETACH, 0x00000000) in "LENTILLE.PFL" called.
DllMain(0x014A0000, DLL_PROCESS_DETACH, 0x00000000) in "LENTILLE.PFL" returned 1 (0x1).
Unloaded "LENTILLE.PFL" at address 0x014A0000.
DllMain(0x64A00000, DLL_PROCESS_DETACH, 0x00000001) in "ASWIDLE.DLL" called.
DllMain(0x64A00000, DLL_PROCESS_DETACH, 0x00000001) in "ASWIDLE.DLL" returned 1 (0x1).
DllMain(0x7FE40000, DLL_PROCESS_DETACH, 0x00000001) in "WINSPOOL.DRV" called.
DllMain(0x7FE40000, DLL_PROCESS_DETACH, 0x00000001) in "WINSPOOL.DRV" returned 1 (0x1).
DllMain(0x65340000, DLL_PROCESS_DETACH, 0x00000001) in "OLEAUT32.DLL" called.
DllMain(0x65340000, DLL_PROCESS_DETACH, 0x00000001) in "OLEAUT32.DLL" returned 1 (0x1).
DllMain(0x65F00000, DLL_PROCESS_DETACH, 0x00000001) in "OLE32.DLL" called.
DllMain(0x65F00000, DLL_PROCESS_DETACH, 0x00000001) in "OLE32.DLL" returned 1 (0x1).
DllMain(0x795E0000, DLL_PROCESS_DETACH, 0x00000001) in "MSVFW32.DLL" called.
DllMain(0x795E0000, DLL_PROCESS_DETACH, 0x00000001) in "MSVFW32.DLL" returned 1 (0x1).
DllMain(0x7FBF0000, DLL_PROCESS_DETACH, 0x00000001) in "MPR.DLL" called.
DllMain(0x7FBF0000, DLL_PROCESS_DETACH, 0x00000001) in "MPR.DLL" returned 1 (0x1).
DllMain(0x7E240000, DLL_PROCESS_DETACH, 0x00000001) in "DCIMAN32.DLL" called.
DllMain(0x7E240000, DLL_PROCESS_DETACH, 0x00000001) in "DCIMAN32.DLL" returned 1 (0x1).
DllMain(0x7FE10000, DLL_PROCESS_DETACH, 0x00000001) in "COMDLG32.DLL" called.
DllMain(0x7FE10000, DLL_PROCESS_DETACH, 0x00000001) in "COMDLG32.DLL" returned 1 (0x1).
DllMain(0x66800000, DLL_PROCESS_DETACH, 0x00000001) in "SHELL32.DLL" called.
DllMain(0x66800000, DLL_PROCESS_DETACH, 0x00000001) in "SHELL32.DLL" returned 1 (0x1).
DllMain(0x70BD0000, DLL_PROCESS_DETACH, 0x00000001) in "SHLWAPI.DLL" called.
DllMain(0x70BD0000, DLL_PROCESS_DETACH, 0x00000001) in "SHLWAPI.DLL" returned 1 (0x1).
DllMain(0x78000000, DLL_PROCESS_DETACH, 0x00000001) in "MSVCRT.DLL" called.
DllMain(0x78000000, DLL_PROCESS_DETACH, 0x00000001) in "MSVCRT.DLL" returned 1 (0x1).
DllMain(0x08370000, DLL_PROCESS_DETACH, 0x00000001) in "DEPENDS.DLL" called.
DllMain(0x08370000, DLL_PROCESS_DETACH, 0x00000001) in "DEPENDS.DLL" returned 1 (0x1).
Exited "PHOTOFILTRE.EXE" (process 0xFFE851BD) with code 0 (0x0).
