Crash with png images
Heis Spiter
Mémoire RAM : 1536 Mo DDR
Message par Heis Spiter »
What's your PhotoFiltre Studio version ?
I'll try with the last one....
EDIT : I've done all you did in your movie without any problem. Perhaps is it a translation problem (Your version is at the same time Italian and English...) ?
I have not either this bug.
Several network admins, with wich i have worked, said that the desktop folder is not exactly an ordinary folder.
And they said it is better to set only shortcuts in this folder and never files. May be Windows has a specific control of this folder ?
Outsider : this bug occurs only when you save as png ? can you tes with tiff ?
Outsider
Message par Outsider »
Antonio a écrit :Outsider : this bug occurs only when you save as png ? can you tes with tiff ?
Yes, it crashes also when i try to save the files as tiff.
well, the bug don't commes from png format...
Can you convert png to 16M befaore saving. Perhaps the bug is in the palette construction...?
