About PhotoFiltre 11 beta (64-bits)
- Version de PhotoFiltre : StuidoX
- Processeur : unknown
- Mémoire RAM : unknown
Re: About PhotoFiltre 11 beta (64-bits)
(This sentence is by Google Translate)
Saving in PNG format will increase the file size.
Since it is close to the BMP format, it seems that it is not compressed.
The setting dialog does not appear when saving in PNG format.
i will try to fix tomorrow
fixed...
On the PNG dialog box I added the new option Optimise :
- checked : use compression level 9 (max but slow) ==> studio X equivalent
- unchecked use the recommended compression level 7 (faster)
confirmed.
Thank you for your prompt response.
I'm going to change my main use to PhotoFiltre 11.
i allready do that, pf11 support big images and lot of new formats
When I zoom in on a vertically long image,
a horizontal scroll bar appears even though there is still room in the width.
You probably didn't consider the size of the vertical scrollbar when sizing the window.
I think you are right, as it is a minor bug I will fixe this summer...
Can you secure your website with even a free certificate? example: https://letsencrypt.org/
Or upload binaries to a service like?: https://sourceforge.net/
I am asking for the security of the downloaded program. Someone can easily attach a virus to unencrypted traffic to the program that anyone is downloading.
https does not prevent viruses it just encrypts the connection. What guarantees is the antivirus on the hosting server and the antivirus on the pc
You're right. The antivirus only works if it knows the virus. And it's easy to get so modified that it won't be detected.Antonio a écrit :https does not prevent viruses it just encrypts the connection. What guarantees is the antivirus on the hosting server and the antivirus on the pc
This is an example of how antiviruses failed:
https://thehackernews.com/2018/04/cclea ... ttack.html
This is an example of how easy it is to hijack network traffic:
https://www.forbes.com/sites/zakdoffman ... ow-secure/
In my opinion, protecting EXE and DLL executable files gives us more security. Keeping checksums on a server with a secure connection is also a good idea. I trust in you. But I don't trust people who manipulate web traffic and create phishing.
I may look paranoid, but prevention is always better than cure later.
- Processeur : --
- Mémoire RAM : --
Can I change the layers menu back to how it looked originally?
I don't like this black look.
not possible it's the PhotoFiltre "touch". But the film effect exists since lot of years (included in PhotoFiltre Studio X & 7)
- Processeur : --
- Mémoire RAM : --
I used PhotoFiltre for many years and there was a way to turn it off, or switch to a grey style like in pic related. Even in the ver. 10. Though I don't remember how I did it since it was so long ago.
yes with the studio version it's possible if you disable the skin and advanced effects like shadowed glyph, but the v11 needs adanced display to support styles and can not be disabled now
- Processeur : --
- Mémoire RAM : --
It seems like a simple cosmetic change, didn't know it was hardwired to something. Maybe you can add a function to turn it off later? The black perforated look is very distracting to the eyes in my opinion, like me eyes actually hurt after some time.
